enblethen
Oct 19, 2016Nomad
Look at the ones under the brass section.
Truck valve stems
I do not know what chassis and dual axle configuration is on your rig. I would go to a truck tire location and see what is being used.
The longer nearly straight ones were used on my inside tire and slightly bent to line up with holes in wheels. The nearly 180 degree ones were used on other dual. They also had to be bent slightly to line up.
Truck valve stems
38,782 PostsLatest Activity: Sep 19, 2026
