glennts's avatar
glennts
Which fridge would you choose?
My Norcold N641 with a 7 yr old Amish cooling unit may have died. Started to get instant NoCo, dealt successfully with this in the past, but this time, even after a new board, cleaning the burner orifice, connections, testing the AC heating element, although there is not a repeat of NoCo there is no cooling. The outside of the boiler stack will burn you but the fins at the condenser top remain cool and the vertical pipe before the fins is hot but I suspect this is from rising hot air from the AC element. So apparently there is no circulation. Spent 6 mos to 9,000' and perhaps that messed up the coolant process??? Running a straight to AC for 24 hrs test to confirm it's the cooler.
In the mean time looking at 12v only units... plenty of solar and lipo4 to support it.
A new 7.7 Everchill is $849 + shippng.
A scratch and dent(door)8.2 Norcold N8DC is $1450 but can be had for $825 + shipping.
The Norcold is a perfect fit for the N641 space which gives it an edge.
Which would you choose?
  • Hi definitely 12 volt.
    I don't think the make is important-but a drop in replacement makes life easier.
    I would go for SiO2 batteries, unless you roll your own Li and NEVER camp in coolish weather.
