valhalla360
Oct 30, 2023Navigator
Campinfan wrote:
The reason why I say four of either is because I would have room for 4. That is why I have the question of 4 12 volts which would give me 4 times the amps of one....or 4 6 volts which would effectively give me 2 12 volts. I hope that clears it up. If all things were even....I would have 4 x 12 volts @100 minutes a piece (just pretending here) so that would give me 400. If each 6 volt was 100, I would only have 200 because I know in series only the volts double not the amps but then they would be partially in series so then I would have the equivalent of 2 12 volt batteries @ 100 a piece for a total of 200. So it seems the 12 volt battery is a better idea until I think about how much lower you can drain the 6 volts.
OK, I see a lot of folks responding are messing up on units and it's causing confusion (ie: someone suggested starting batteries have 3-5times the amp-hours for 30 seconds...which makes no sense).
Voltage:
- By wiring them in series, you add the voltages (ie: 2 batteries at 6v puts out 12v power.
- by wiring them in parallel, the voltage stays the same (ie: 2 bateries a 6v put out 6v power.
Amperage: For house loads, it's all but irrelevant unless running a big inverter. Amperage (typically shown as CCA~Cold Cranking Amps) is usually of concern for starting an engine. No harm in using a starting battery to start a engine but for the same size battery bank, a deep cycle will have fewer CCA.
Amp-Hours: This is a measure of the amp draw times the duration in hours. If you pull 8amps for 10hours ~80 amp-hr. It's important to understand that to use it correctly, you have amp-hr @ X volts.
Watt-Hours: If you are comparing batteries of different voltages, it's often better to convert t watt-hr. Watts = volts *amps. So 12v @ 10amps = 120watts. If you draw that for 10hr, you will use 1,200w-hr.
Once catch is how fast you deplete the battery will impact how many amp-hr (or watt-hr) the battery will put out. This is why 5 minutes cranking a truck engine will kill a 70amp-hr battery. Theoretically, 500amps for 5 minutes will use just over 40amp-hr but the battery likely won't crank the engine anymore. (look up the phuerket effect if you want more details).
So let's take your example of 4 12v Group 27 batteries vs 4 6v golf cart batteries wired for 12v:
- The 12v batteries will have around 90amp-hr each. Since you aren't changing voltage, you can multiply to get the total amp-hr ~ 360amp-hr total.
- The 6v batteries will have around 220amp-hr each but when you merge 2 to get 12v power, the amp-hr stays constant. Since you are combining 2 sets of 2, you wind up with 440amp-hr total (importantly @12v)
440amp-hr is significantly more tan 360amp-hr and hence why the 6v batteries are preferable.
Another way to calculate it is watt-hr:
- 12v @ 90amp-hr * 4 batteries = 4,320w-hr
- 6v @ 220amp-hr * 4 batteries - 5,280w-hr
You also get a little boost from the phuerket effect mentioned above as you are drawing at a slower rate (relative to the battery bank size) with the 6v.
Someone suggested it's OK to take the bank down to 20%...if you immediately start charging, it's only minor damage but if they will sit at 20% for hours, yes it does degrade the batteries.
PS: Lithium is very deferent in that they are largely unaffected by taking them down as low as 10%. This allows you to get away with a smaller battery bank in terms of amp-hr for the same usage. It does come with some catches in terms of management and proper charging or you can ruin an expensive set of batteries easily...but it's getting better.
38,782 PostsLatest Activity: Sep 10, 2026
