pianotuna
Oct 30, 2023Nomad III
Properly set up is not possible unless you wish to buy a special purpose alternator. Or add a diode type device to the existing alternator.
The computer in the engine "looks" at the starter battery voltage. When the starter battery has recovered--charging is scaled back. Once that happens there is little or no charging of the house bank.
A dc to DC takes the incoming voltage and boosts it to an acceptable voltage for charging the house bank.
My dc to DC charger does a maximum of 20 amps. That works out to less than 5 amps per battery.
Because I have a larger than usual bank, I chose to set the output voltage of the dc to DC at 14.7 volts. Don't do this unless you have researched what the ideal charging voltage is for the house bank.
38,782 PostsLatest Activity: Sep 10, 2026
