Whatever you buy I would make sure to have someone, either private or business, to check out the MH prior to purchase. Many Class Cs have leaks in the roof that allow water to get into the walls and cause delamination. That is where the water has dissolved the glue that holds all things together in the walls. Usually that makes for repairs that cost more than the motorhome is worth. You may get a place that takes RVs for rent to take yours for a rental but they usually want new ones to rent.
