I have a 1992 Georgie Boy Cruise Master that is on a Chevrolet P30 Chassis with the 454CI gas engine. It needs new shocks and want to do it myself, but I'm having difficulty finding out which shocks t...
I have a 96 GBM on a P-30 chassis. From my research the Koni's work better for a heavier chassis like what Mike Brez posted. What does your chassis weigh? I am guessing 13,000 lbs UW and 15,000 lbs fully loaded. I think you will like the Monroe shocks. I would check your ride height on your front end before you add the shocks you should have 1.75 to 2 in clearance between the bumper and upper A arm. If not new HD coil springs would be in order and will greatly improve your ride.
