starcrwzr's avatar
starcrwzr
Which Shocks?
I have a 1992 Georgie Boy Cruise Master that is on a Chevrolet P30 Chassis with the 454CI gas engine. It needs new shocks and want to do it myself, but I'm having difficulty finding out which shocks to get. I see shock part numbers for chassis without Monobeam front suspension and numbers with Monobeam front suspension. Is there an easy way to tell what my front suspension is and what the rear is as well ( I know it's leaf springs)?
Scott B
Julian, CA
  • I like the Koni FSD shocks because they ARE NOT gas charged and therefor do not transmit the road joints and other small bumps back through the suspension. The Koni shock also perform better than my previous Bilstein shocks on large bumps and to control sway.
  • I put Koni's on our new MH (2600 miles) to resolve some issues with the stock shocks ( dipping when stopping and too much body roll - side to side and front to back). They were immediately noticeably better. About $900 installed.
    Not to say others aren't good, but after my research that's what we chose. Very happy with them.
  • Any heavy duty shock will work fine, some people think Koni (sp?) shocks are the best, but are they so much better that a regular HD shock to justify the extra cost? I don't know. I went with Monroe HD shocks on my 1987 P30 and I am very pleased with how they work.
  • Your 92 P-30 chassis should have an Independent Front coil spring Suspension with ball joints in upper & lower control arms, Non Monobeam.
    If push comes to shove you can always remove one of the shocks take it to an auto parts store to find a like type shock that will fit.
    Good luck with your project & keep us posted...
