FIRE_UP's avatar
FIRE_UP
Who knows about FCCC "MMDC" and its issues?
Gents,
I've searched and read many issues regarding the old "VDC" units and the newer MMDC units. I'm thinking I may have developed an MMDC issue. Here's the scenario. We're presently on vacation and all has been going well. We were on the freeway, I-10E, just outside of Lordsburg NM when all of a sudden, the speedo started dropping. I had the cruise set to 60. The speedo started dropping, stumbled a bit, then fell to zero.
The rig was corresponding to that too. In other words, the cruise had been shut down. Along with that, the tach went to zero, the oil pressure, water temp, turbo boost, and voltage gauges, all died. I think the air pressure gauges for both front and rear are still operative but, I can't remember (we're camped in Silver City NM right now). Another problem, and a serious one, the exhaust brake QUIT!
And, on my annunciator panel, the "ABS" has lit up, and "Check info center" is also lit up. When I look at the Medallion Info Center, it's reading "No data from Trans ECM and NO DATA from Engine ECM for 25 seconds", and is flashing that over and over.
Now, with all this going on, here's the deal. The engine is still running like a top. The trans is still shifting and operating flawlessly. All the lights, turn signals, brake lights and most other normal electrical stuff is still working just fine. And, I also have what's known as the "Trip-Tek" computer on board too. And, to those of you that don't know what that is, or don't have it, it's a system by which additional information, engine stats, trip odometer(s), maintenance items and more, are displayed on the monitor of the back up camera.
Well, since I lost all important gauges, I hit the Trip-Tek and all the engine stats, oil pressure, engine temp, trans temp, etc. are still just fine and operating just fine. My fuel gauge is working just fine.
Well, I pulled off the road, into town, and got lunch. Then we pulled the rig onto a side street and I called Freightliner help. They started to direct me to the MMDC 10-pin plug. They say those pins can get damaged due to the weight of the harness(s) in that area that tugging away at the plug. My phone was acting up too so I was in an out of the conversation with the Freightliner tech so, I thanked him for his time and went out and pulled that 10 pin plug and looked at it.
It looked just fine to me. Now, I also talked with my son, who works as an RV tech in San Diego and he has replaced many MMDCs due to faulty soldering on and in the pc board inside them. That's the same issues the older VDC units were having. What's up with these boys that do these boards? Anyway, to those who've had issues with the later MMDC units, did you have the same or close to the same symptoms? Is there a way to tell if the MMDC is actually bad without taking a chance on $400 or $500 worth of experimenting?
As stated, my speedo quit and so did my odometer. Now, to me, that's kind borderline "illegal" isn't it? I mean, heck you could drive that thing for another 100K miles and then get it fixed and, sell it as a "lesser mileage" vehicle". But, that's beside the points here. I sure could use some help here.
Scott
  • I am not following the acronyms ... but it sounds like you are talking about your electronic dash/info center. It sounds like the dash has lost its data connection to the chassis J1939 data link. If you can locate the connection where the data cable connects, the resistance between the two wires coming from the chassis should be around 60 ohms.
