Dakzuki
Aug 01, 2013Explorer II
navegator wrote:
Note: If you do your own oil change take something like an ice pick and make a hole (small no need to impale)on the oil filter to drain the oil, less mess when taking it off, and do not forget to lube the rubber ring on the filter so that it slides when you are tightening it, the lube prevents the ring from dislodging or kinking and creating a leak.
navegator
I'm spoiled. Mine is on top of the motor in front. Removable element that drains back into the housing when removed.
38,782 PostsLatest Activity: Sep 10, 2026
