et2's avatar
et2
Who treats their diesel fuel?
I know it's been discussed if you should on this forum and the associated debates. My question is to those "who do", have you had any issues?
In particular ours is stored from fall to spring 6-7 months without any road driving. So we keep the tank full at 100 gallons. Been using the Power Service products for years. Clear Diesel fuel and tank cleaner for stabilation and water removal. Use this all year and add at every fueling. In the fall I add winter fuel conditioner as well.
Just this last fueling added a Diesel Kleen and Cetane boost. Suppose to lube the injectors and clean them.
Now that just me. I lean toward a little prevention vs hoping everything will be alright. I got that attitude after flying private aircraft. A whole lot of required preventive maintenance goes into keeping a plane airworthy. Like keeping the fuel tanks full at all times. Every flight is preceded by a fuel check for water. Which I have found even with full tanks.
So that led me to believe our MH systems aren't any better. Except we do have water separators. I'd rather not put all my trust in them.
Anyone have problems caused by using these products?
