wolfe10 wrote:
Have weighted each coach we have had-- individual wheel position weights.
Only way to accurately determine tire pressure.
The correct PSI for our tires per Michelin inflation tables is 70 or 105 depending on load. That is WAY too large a range to guess at.
There is NO way any table would have our class A's tires at 70 psi, ever. Every tire has a weight range based on the weight they are handling. I can tell a lot from just looking at a class A and can see what weight range they are in. DPs are the heaviest and should always be inflated to what the chassis manufacturer states. A newer DP will be running at 3500 lbs or so less than GVWR should always be at max PSI according to the manufacturer. Weighing should be to see how close to GVWR and the distribution of the weight not whether or not you can deflate your tires for a better ride!
No, I have not had mine weighed. I already know that it is "very heavy". Sometimes I am just curious and may run it on a scale eventually.....
