SCVJeff
Aug 28, 2016Explorer
westernrvparkowner wrote:its actually worse than that now that I think of it. The Honeywell I have is WiFi enabled, but it needs to talk to the Honeywell server in order to function at all. So in a CG it might be interesting to attempt to get it to talk to the local WiFi unless you haul along a hotspot with the thermostat pointed at that. I'm sure there are other issues to pop up too.SCVJeff wrote:The problem will be you have to connect to a wifi connection to enable the features I am sure they want to use. Wifi thermostats I am familiar with will only connect to a connection you manually set up, so you would have to reconnect it every time you move. They aren't just plug and play, so to speak.
You can adapt almost anything to work
(Edit spellin')
