Bside60
Oct 05, 2013Explorer
camperdave wrote:
I'm not sure how an E450 would help you anyway, sine you are flat towing (ie: no tongue weight). The biggest advantage is the extra GVWR, isn't it?
Here is some of what I've found regarding the E450 advantages over an E350: "an E450 gives you bigger brakes for more time between brake jobs, more transmission cooling for less heat load on the engine and longer transmission life, a 4.5 inch wider rear dually stance for better lateral stability offroad and in high side winds, pump boosted power steering instead of vacuum boosted power steering, thicker steel in the chassis frame for less frame torsional twisting transfer into the coach box, and lower differential gearing when pulling up long grades for less heat load on the V10 in hot weather".
I am still learning though and value any opinions.
38,766 PostsLatest Activity: Jan 10, 2026
