- booty51ExplorerFord customer assistance sounded good to me. Also won't road service provider help with this as well? Good Sam, CoachNet.
- booty51ExplorerDo you have a road service provider. They will chase a ford or chevy dealership down for you that will work on your MoHo they have for me.
- tatestExplorer IIFord truck dealers will, car dealers won't. They don't have the lift equipment or large bays, they don't stock truck-only parts.
This is an issue mostly in metropolitan areas where there are multiple competing dealers and separate truck centers. My experience in rural areas in the middle of the country is that all Ford dealers are truck dealers, all GMC dealers are truck dealers, and most Chevrolet dealers are truck dealers. FCA is still trying to sort out dealer arrangements. - GjacExplorer IIII have found whether it is a Ford or Chevy most dealerships don't want to work on large MHs because of the bays and lifts that are required. Also the independent ones that are big enough would prefer to use their bays to work on trucks. I found that Meineke muffler in my area will work on and have bays big enough to accommodate large Class A's.
- MondookerExplorerIt sounds like you better figure out who does scheduled maintiance well before you need it. Especially if your not home riding the highways and byways.
- rk911ExplorerScheduled maintenance does not need to be performed by a Ford dealer in order to maintain the warranty. all that is needed is proof...receipt from the service provider...that the service was performed.
- afrescopXxExplorerMy local Walmart has a large service bay and will do an oil change even though I probably would not go there. My issue with them is that they are used to driving cars in and out not a MH.
As far as Ford dealers go, I have found that many dealers in rural or suburban areas will service the MH. The V-10 Triton engine is in many smaller Ford vehicles that Ford dealers service regularly. The issue is in the size of their service bays. - nbkingExplorerA Ford dealer offered to do a $19.95 oil change on my Roadtrek for $75.00 because, he said, he would have to do it outside.
I declined and found a quick oil change business to do it. - rr2254545Explorer
Kaz wrote:
Mondooker wrote:
Will a Ford dealer perform scheduled maintenance on a motorhome like oil change etc with the 6.8-liter V10 engine?
If the answer is yes, will they also perform engine, brake and transmission work on the motorhome, or does it have to a Ford truck center? Or do you take it to an RV dealer?
I was having a dickens of a time finding dealers convenient to my location, so I called the Ford customer assistance number (1-800-392-3673) listed in the chassis owner's manual (not the motorhome manual). It was hard for the operator to find one so she promised to call me back. Thirty minutes later, I got a call with 3 relatively nearby locations. She apologized but explained that it took her that long because she personally called each one (!) to make sure they could and would work on a motorhome. So far, I've used the dealer only for scheduled maintenance, but they seemed happy to do the work.
Same deal when I lost the torque converter while on the road. The Ford customer service folks (roadside assistance in this case) took responsibility to find a place that would work on a motorhome transmission and then called me back.
If hunting around on your own isn't working, give the Ford customer service folks a shot. I'm sure they can help.
No wonder Ford didn't need a bailout!
Skip
x2 this was what I did and they came through every time - the problem is that some dealers do not have a service bay that will fit a motor home - KazExplorer
Skip
38,767 PostsLatest Activity: Jan 13, 2022
