CVD's avatar
CVD
Wind sense awning – worthwhile?
What’s the consensus on a wind sensing awning? Do they work? Reliable?
My thinking is I’d use the awning more if it had an automatic retracting feature. I camp in the desert frequently and am afraid to leave the RV for the day with the awning out, in fear of heavy wind popping up and destroying the awning.
BTW - I’m in very early phases of shopping for a newer rig. The Newmar Ventana (4038) has about every feature on my wish list, except a wind sensing awning. The Dutch Star does have it, for an extra $40 - 50k.
  • Effy's avatar
    Effy
    Explorer II
    If you've ever seen an awning retract it's easy to conclude that it would never retract in time before damage is done if the gust is strong enough. I am not sure I understand the logic behind self retracting awnings for this very reason. Any manual tells you anyway to never leave it out and unattended. We always pull ours in if we leave for any length of time. I've seen a few awnings with bent arms.
  • Never owned one but I have seen two at campgrounds wrapped over the top of coaches due to a sudden wind burst. So if the wind give the awning a coupe of easy warning gust it will retract but it it is just hit with one big gust it is over your roof before it has time to sense it and retract it.
    Same with a manual, if the wind give you warning gust you can put it in, if not it can be over your roof before you think about it. I have an old fashioned manual on with down supports that I think take wind better than the scissor ones with no downward support. But then are a lot more work to open and close. But I would not leave for the day with any large patio awning out. I leave my window awning out.
