MagillaGorilla wrote:
If I cover the top 33% of the windshield with 50% tint that would give me a 15% reduction on light as well as a reduction in heat. When parked is not the issue its when driving.
IF you could cover that much of your windshield, you'd be at an attention getting / pull me over level....an inch or two below the AS1 line is one thing, but covering 1/3 or more will surely get unwanted attn.
you might want to look into some of the HEAT & UV blocking / clear films - you could cover the entire windscreen with that (since it has minimal if any TINT).
http://wot.motortrend.com/3ms-window-films-block-heat-uv-rays-dark-tint-77391.html#ixzz1MH2xvMJD
