Bossandbabe's avatar
Bossandbabe
windshield coming lose
I have a split windshield and the padsenger side is popping lose at upper right corner. Then extends downward. It was that way when we bought it, had it put back in place (didn't see what they did), later it cracked. Got worse, replaced it. Now its separating again. Any advise?
  • We had the same issue. It came out, cracked and we had it replaced. Glass guy warned that once it has happened it will continue to happen unless we take precautions. Always try to make left turns when possible instead of right turns because by making wider turns around corners and into driveways it helps keep the front of the coach from flexing. Also try to lower and retract levelers together as much as possible to eliminate as much twisting of the frame and body as possible. Instead of extending levelers a longer distance use blocks under the tires to gain closer to level in those really unlevel areas.
    Hope this helps but I am right there with you and in the same boat!
