C20's avatar
C20
Windshield seal
I have an 08 Itasca, and the windshield seal leaks. It also came off when a truck passed me once and I had it put back on. It has since come off again, and I stopped and bought the 3M windshield adhesive and a new seal.
The seal is like the old one, but when I put it on it barely fits the gap. There is hardly any seal left to put the adhesive on. So that brings me to two questions.
Do they make a seal that is wider so more adhesive could stick to it?
Could I just fill the gap with the windshield adhesive, and then put a piece of Eternabond tape on it and not put the rubber back on at all>
This is the seal at the top of the windshield that I'm talking about. It goes from one side to the other in one piece.
Thank you all!
  • It is still a Winnie problem with our 2914 Winnie. I took the seal out, cleaned up and recaulked as best I could. Then glued and sealed the edges of the seal. Then covered the entire seal with 4” wide electrical tape( any good tape would work) and finally put a stick on gutter above the windshield to stop roof runoff from coming down
    4 years later, no leaks.
  • Bruce,
    It is rusted. The last time I had a windshield put it it had quite a bit of rust on it. They got it put in but wouldn't guarantee that it wouldn't leak. The leak is intermittent, and not bad, but I'd like to seal it up. I thought that by filling the void with the adhesive then using tape instead of rubber it might make a better seal. The next time I need a windshield I'll take it to Winnebago and have them fix the rust and make it right
  • Any chance the structure is rusted out?
    I haven't read of many lately but it used to be a common Winnie issue.
    If it is you'd be better off removing the windshield and getting it fixed properly.
    There has to be a reason for the issue you're having.
