Argosy24
Nov 18, 2013Explorer
Drain the fresh water tank and only put the rv antifreeze in the water lines. I disconnect the inlet line to the pump and use one of the flexible faucet hook up hoses to draw from the bottle of antifreeze.
There should be low point drains to empty water from the lines, drain the water heater. There should be a bypass valve setup so you don't have to fill the water heater to fill the hot water lines. Dump enough antifreeze down each drain so it fills the traps and displaces the water.
38,782 PostsLatest Activity: Sep 02, 2026
