peterman1's avatar
peterman1
windshield wiper arms keep breaking
hey guys I have a 2008 fourwinds hurricane class a I purchased the rv in 2009 brand new and after the first year one of the windshield wiper arms broke. I called tru vision and replaced the arm myself. well then about a year later the second arm broke. I figured it was fault cause I was to hard on the first set of arms when washing. well we were driving the rv to Davis mountains this week and another arm broke off. each wiper arm is a double post.. any ideas what I should do? thanks for any advice
pete
    pete
    2008 and 2009 tiffin buses had the same exact problem.The arm was redesigned and replaced under warrenty if you owned a tiffin bus and experienced the problem and complained to tiffin
  • thanks for all the good ideas.. when I order the new one im going to order 1 extra and im going with all 28 inch blades.. thanks again
  • Had a similar issue so I switched from 32" wiper blades to 28" and that solved my problem. The 28's still clear the windshield fine.
  • Sounds like a design flaw....probably should order two and keep a spare handy.
  • Could you clarify where it is the arms are breaking?
    I was thinking that the arm might be something that could be brazed or welded.
