bsandy56's avatar
bsandy56
windshield wipers
33 ft. class A with chevy 454. Took the wiper motor off to look for the pulse board. It dosen't have one like i seen on u-tube. Could the pulse board be located some where else. I have it hot wired with a switch for now but would like to fix it right. Hope some one else have had this problem and fixed it there self. bsandy
  • MountainAir05 wrote:
    Are you just by-passing the wiring and using the regular switch or you added a on/off switch and new wire. Some had a cam inside the cover you took off and several sets of switches. The on/off switch on the steering wheel could be bad or a loose connector.
    I have added a on and off switch and new wire for now.
  • Are you just by-passing the wiring and using the regular switch or you added a on/off switch and new wire. Some had a cam inside the cover you took off and several sets of switches. The on/off switch on the steering wheel could be bad or a loose connector.
