Has anyone changed out their existing crank up Winegard to a King Jack? Is there electrical power to the Winegard? I see on the installation of the King Jack you add power? Thanks in advance.
I replaced the bat wing crank up with the fixed position jack antenna. Once less item on my pre-drive check list. The mounting plate is a flat square which makes sealing much easier. Power for the antenna amplifier comes from the same source as the bat wing via the coax. Performance is slightly better. Most noticeable is the jack isn't as directional as the bat wing.
