dobbler98 wrote:
We recently purchased a 2004 Holiday Rambler. It came equipped with the Winegard Video Selector Box, has the crank-up Winegard antenna, and a Winegard Stationary and in-motion Satellite Dish. The Box won't turn on. We have checked all the fuses and breakers; all are good. Would there be an in-line fuse somewhere? Yes I have disconnected the antenna coax and it still doesn't work. Can't get power to the antenna to check the head. The TV has power and is wired into a +12v box. The Video Box is wired into the same +12v box.
Additionally, the dash radio and the 12 volt fans on the windshield don't work either so I'm wondering if they could all be on the same circuit?
Thanks,
deb
what would make u think disconnecting the antenna coax would make it work?(just curious)
The fuse that runs dash radio and fans may or may not be.Best try that avenue first. Now if its the box iam thinking of you only need 12 Volts to power the OTA antenna The box switches manually just like a AB switch
