rhoderunner's avatar
rhoderunner
video selector box
Hi
New to the 4um and to owning 2001 Safari Panther. Looking for assist with TV issues.
:h
(1) connecting the bedroom tv thru video selector box.
(2)Living room TV is a DELL with speakers that snap, crackle and pop louder than a bowl of Rice Crispys with garbled audio. So if there is no solution found for that we will be replacing it. Antenna I think is Windgard crank up. Thanks for the assistance
  • Make sure your tv input is selected to the correct source as stated by rk911.
    Walter
  • rhoderunner wrote:
    Hi
    :h
    assuming you're trying to watch over-air-tv (OTA):
    - select ANTENNA on the video switch
    - select BEDROOM TV on the video switch
    - if the bedroom TV is NOT digital be sure you have a digital-to-analog converter box between the TV and video selector switch.
    - if the bedroom TV IS digital be sure you select ANTENNA on the TV's menu/source and then SCAN for channels.
    do the same for your living room TV. you must re-scan for channels everytime you move to a new park or campground in an area that would have different OTA channels. for example I would need to scan for channels when camping in the Chicago area and then re-scan if I move to the Indianapolis area.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
