Hank85713's avatar
Hank85713
winnebago and flush mounted lights
Question. We have a 21012 Winnebago Aspect and one of the lights has burned out over the dinette. I know they twist the lens off but I have one that I cannot get to move. Has anyone else had this issue and what did you use.
These are the ceiling flush mounted flat lens light take a H5 Bulb I think it is. I took the one off I had a bulb go bad in before and it has small dimples to hold it in once turned but for whatever reason I cannot get a grip on the current one.
Thanks Hank
  • I got rid of all those halogen bulbs and converted to LED. Same color, same brightness, no heat, and no more burning out bulbs.
  • As said, a slight pull down and a bit of a twist.
  • In my rv you can pull it down a little and get a better grip on the lens. You can take it all the way but be careful because the light is held in place by strong springs . Acts like a mouse trap.
    Don
