dougrainer
May 25, 2015Nomad
Fleetwood had a roof sealant recall/TSB just before they went under. Eternabond is used by a number of OEM's and it is used where you CANNOT use seam or Dicor sealant. Like the box seams of a slide room on the roof. They also use it at the front and rear caps to roof edge to help keep a good seal from the normal flexing. Eternabond is NOT a work around fix, but a legitimate product for a install or repair. Now, We are no longer a Winne dealer, but I would bow to THEIR reason for using Eternabond for the TSB/recall, as they have been in business for 50 years. They would not want Eternabond used unless they have tested it for the specific problem. Doug
38,782 PostsLatest Activity: Sep 10, 2026
