- MartynNomad
Kountryguy wrote:
Has anyone found a way to receive notifications of power loss in the coach when you are away from the unit?
Look at MARCell units. They run off wireless. Cost about $170 then about $90 a year with AT&T or Verizon. If the power goes out, or temps go out of set range, you get a text and/or e-mail.
Great for RV owners with pets.
MARCell - 2oldmanExplorer II
Kountryguy wrote:
Then I guess you'd know there's a problem.
The problem is when the power goes out, so does the wifi. - rlw999ExplorerThis is probably overkill for you, but my Ring Home Security System will notify me when the power is lost. It has a built-in battery backup along with cellular backup so can send notifications without internet (but obviously it needs to be in cellular range (I think it uses AT&T). Looks like the cheapest system costs $200 so is expensive for just a power monitor, but comes with door and motion sensors if you want to be notified if someone breaks in.
- KountryguyExplorerWill have to check into that.
- rk911Explorer II
Kountryguy wrote:
I am in an RV using a small travel router.
so are we. our verizon mifi router works on both AC and 12v. if shore power drops the router reverts to 12v - KountryguyExplorerI am in an RV using a small travel router.
- rk911Explorer II
Kountryguy wrote:
. unless the router is dual powered..like ours.
The problem is when the power goes out, so does the wifi. - KountryguyExplorerThe problem is when the power goes out, so does the wifi.
- rk911Explorer IIor maybe a plug-in, wifi enabled power failure detector like this.
https://www.amazon.com/dp/B089QQNKJL/ref=cm_sw_em_r_mt_dp_PD91M17090D4KT3476XH?_encoding=UTF8&psc=1 - 2oldmanExplorer IIA nest camera pointed at a voltmeter might do the job.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
