Rick_Jay
Aug 25, 2021Explorer II
Two travelers,
The water is getting in from elsewhere. :) Perhaps a failed seal on the lens?
Are the front lenses plastic like most are now? If so, the brute force way of dealing with the issue is to put the vehicle on level ground, use an 1/8" drill right in the center of where the water is collecting and drill through it from the outside. That should allow any water to drain out.
Good Luck,
~Rick
Good Luck,
~Rick
38,782 PostsLatest Activity: Aug 31, 2026
