chuckftboy
Aug 26, 2021Explorer
Just like a double pane window, if the seal fails eventually you will end up with moisture in and 6 or 7 years is about average before failure. During the day the air inside heats up, expands and leaks out. During the night the air inside cools, condenses and pulls in moist night air. Any metal inside will eventually rust and replacement is the best fix but it will happen again some day.
Sealed, glass beams back in the 60's and 70's seldom had the problem but the foreign manufactures don't properly seal the plastic.
38,782 PostsLatest Activity: Aug 31, 2026
