- Mich_FExplorer
fourthclassC wrote:
All great replies. Thanks to every one. I now have some ideas to improve this wierd (for me at least) sewer outlet area. Also thanks for the molding/sealing alert. Always interested in any other Winnebago Mini specific issues/characteristics.
That molding/sealing alert is by no means Mini specific. It applies to any class C with that same style front cap construction. Unfortunately I've read of Cs with the full fiberglass caps, even though they don't have seams in that position, also having leak issues. Some of them are on brand new units. - fourthclassCExplorerAll great replies. Thanks to every one. I now have some ideas to improve this wierd (for me at least) sewer outlet area. Also thanks for the molding/sealing alert. Always interested in any other Winnebago Mini specific issues/characteristics.
- CloudDriverExplorerWe also have a 2003 24ft Minnie. The bottom of our sewer compartment hasn't rusted out (yet), but if it does in the future I probably won't bother fixing it. The space isn't sealed from the outside anyway, as there is lots of gap around where the pipe from the gray tank comes in. If anything, having the bottom plate missing will make it easier to connect the sewer hose to the outlet.
Just as a heads up for a new Minnie owner, make sure you check the seam at the bottom of the cabover where the outside wall meets the side to bottom trim strip as shown in the picture. I had a leak on the passenger side that resulted in some wood rot of the cabover floor. Pressing on the side wall just above the trim opened a gap between the wall and the trim strip. I keep it sealed with Dicor caulk and check for cracks in the caulk several times a year, resealing as needed. Not necessary to do a sloppy bead as shown in the picture.
- midnightsadieExplorer IIsquare plastic fence post would make a good holder. or round.
- Mich_FExplorerIt's hard to make suggestions without seeing the problem. Perhaps a larger pyhi deck plate would solve the issue
http://www.beckson.com/prydp.html
If not, maybe a trip to a metal fabrication shop would be the answer.
38,763 PostsLatest Activity: Dec 05, 2025
