haddy1 wrote:
predawn wrote:
haddy1 wrote:
I don't know why some of you are being so cynical about using Eternabond to seal the roof. In the Winnebago case, it's being used to seal the joint, not "hold the roof down" as someone suggested.
That's exactly what that tape is for. Tiffin uses it over the joints between the roof and the front/rear caps. Once again, it's used to provide additional protection to the joint. Any properly prepared joint that is covered by Eternabond will never need any more attention for the life of your coach.
They do? I am on my second Allegro bus and there is no EB sealing anything other than my roof radius cracks till Tiffin repaired my roof under warenty this fall
How old is your bus? My 2012 Phaeton has the tape front and back as described.
2008 and I have worked on a friends 2010. No EB sealing of any kind
all use the self leveling white sealant you always see
