rokitman
Jul 30, 2013Explorer
Winnebago sewer outlet
I've got a 91 winnebago chieftain, and the sewer connection is a pain. The connector is angled down slightly ( presumably to allow 'easier access to connect the hose through the access hole in the bottom) but it seemed to be a very tight fit between the outlet and edge of the compartment for any of the connectors I found. I seem to always have a problem getting a good seal. I believe it's unchanged from the factory, but I'm not sure how to get a good seal. Do these outlets wear?? Is there any tight 90 degree couplings out there? i tried a 'normal 90 but theres not enough room for it... Any suggestions?
