VAWinger's avatar
VAWinger
Winnebago Vista 27N - Cargo Capacity?
Looking at the Winnebago Vista 27N. I cannot find any specs on the dry weight (unloaded weight) or cargo capacity on any of the Winny Vistas.
We have been looking at class C's in the 30' range, but most seem to be maxxed out on GVWR not leaving much for cargo and passengers. That's what led us to look at some smaller Class A's. Can anyone tell me where to find the Net Cargo Capacity or Unloaded Vehicle Weight on the Vistas?
  • PawPaw_n_Gram wrote:
    I am not really finding a typical UVW or Empty Weight listed in the specs of almost any Class A or Class C - from low end to million dollar DP units.
    GVWR, GCWR and Axle Loads are about all the weights I can find.
    These vehicles are subject to similar weight reporting regulations as those for cars and trucks. The Vista Manualshows the "Occupant and Cargo Carrying Capacity" label required for all Class A units on page 1-3. The carrying capacity is dependent on what options are included, so you won't find a "general" UVW value
    Note that there is an additional label required if the anything weighing more than 100 pounds is added by the dealer. The regulations are pretty tight!
    I have found the OCCC's for the coaches I am interested in by looking at the labels in the actual units. If you can't find a 27N nearby, you might be able to get the information from Winnebago if you specify the options.
  • I am not really finding a typical UVW or Empty Weight listed in the specs of almost any Class A or Class C - from low end to million dollar DP units.
  • Spec sheets are right here on the Winnebago Site. Although they don't usually list the dry weight due to that being different for every vehicle depending on option content.
