Hank85713
Aug 11, 2015Explorer
Sounds as if the hydralic line is not holding pressure and the up spring is what is pulling it up. You probably need to either go to a shop and have it checked fixed or maybe there is some air in the line and thats why it pulls up from the spring pressure. May need to bleed the line for air. Check you manual on bleeding the jack.
38,778 PostsLatest Activity: Jun 06, 2026
