Ran's avatar
Ran
Winter Storage Question
Folks,
We have an '08 Damon Tuscany 4072 DP. For the past several years, we owned a property where we've had the luxury of inside storage wherein we were able to keep the unit plugged into 110V for battery maintenance during extended periods of non use. We've since moved south (from northern WI)to a home in the Charlotte, NC area where not only is there no space to park the MH, but we are also stuck (at least for now) with a nearby secure outside storage...but without power.
I'm not worried about the MH sitting without being plugged in during the 7 to 9 months of the year that we use it regularly. But I 'am' concerned about the winter months when it will sit idle for 3 to 4 months. Obviously, I'll put the batteries in 'storage mode' (the unit has a switch by the entry door to take residual loads off the batteries during storage), but I'm wondering what advice you guys might have to keep the batteries up during those winter months. Do I remove the chassis batteries and keep them on a maintainer? Do I remove all the batteries? (Yikes!). Do I invest in a solar charging system capable of 'float charging?' Or do I just make sure the batteries have a full charge before storage and hope for the best??
Winter temps in the Charlotte area aren't very 'winter like' compared to northern WI, so I'm not nearly as concerned as I was when we lived up there. But I still need to find a good solution to keep our batteries maintained during storage.
Thanks in advance for your help..
Randy
