Effy
Nov 13, 2014Explorer II
Most newer MH's, even entry level ones, have the air ducts run in a way to provide residual heat to the tanks. In order for your tanks to get damaged they would have to be almost full and freeze solid. running heat indoors will certainly keep the inside plumbing from freezing. I would just make sure you winterize the outside shower. I'd probably be more concerned about running out of LP. It also sounds like you'd have to run your gen a good bit to keep batteries charged.
38,769 PostsLatest Activity: Jun 25, 2013
