jwrcrr
Nov 09, 2014Explorer
Winterizing 2014 Coachmen Freelander 31DS
I am attempting to winterize my 2014 Coachmen Freelander 31DS. The booklet which came with the RV says to put RV antifreeze in the fresh water tank, then run the pump to circulate the antifreeze throughout the plumbing. I can't get the antifreeze into the fresh water tank. The instruction booklet does not tell you how to do that; says you will need a long funnel. When you use the funnel, the antifreeze runs down the side of the RV. The dealer omitted this item in his pre-delivery walkthrough.
After much twisting and turning, we were able to bypass the water heater. But no antifreeze in the system.
Any help or advice would be appreciated. Thanks!
