John_S_
Nov 13, 2014Explorer II
Your batteries will not make it long enough so the genny is required but if it si not too cold out then you should be fine. I will say that I try not to take my born free in freezing weather for any period of time. I cracked the pipe coming out of the black tank that way. No heat or insulation on it and it was just driving it home one day in the cold but it was 15 degrees. I had antifreeze in it but it did not matter. Now the Foretravel has been down to below zero with out a hiccup.
38,769 PostsLatest Activity: Jun 25, 2013
