Fishinghat
Oct 07, 2013Explorer II
I wouldn't use the on board air compressor or any other air compressor. Use the blower end of a shop vacuum. It has enough pressure to blow the water out without damaging the plumbing. I have also used my shop vacuum on my pool every fall for over 25 years and haven't had any problems.
incidentally, I also use the red RV antifreeze to just make sure no remaining water stuck in some low spot will freeze and damage something. I also pour at least a quart into each tank for the same preventive reason.
38,766 PostsLatest Activity: Jan 10, 2026
