- Johno02ExplorerWhat ever happened here?? did you get it winterized?? Did my postings help?? Hope you got it taken care of!!
- Johno02ExplorerBetter shop of Antifreeze connector and pickup hose before connecting. Note empty lines.
Connected and pumping. Note pink stuff in water lines.
Anode rod as it came out of Hot water tank.
Anode rod after light wire brush, ready for next year.
- Johno02ExplorerAntifreeze hose connection on left side of water pump.
can't see it very well, connection is behind lamp, but the white coiled hose on the back is my tube to suck antrfreeze from jug.
- Johno02ExplorerOur 2005 Gulfstream Ultra Supreme has a connection with a rotating tap just ahead of the water pump between the tank drain and the pump. You will need a fitting barb and a short piece of plastic tubing. Gotta do mine in the morning, so if you can't find it, I will post pictures for you. Drain and bypass water heater. close all drains, attach hose to connection, stick hose end into antifreeze bottle, and start pump. Open each faucet until pink stuff runs out. be sure to do toilet, toilet sprayer, and outside shower if so equipped.
