PapPappy
Oct 03, 2013Explorer
What you have should be fine!
Keep in mind, you will be building up air pressure behind the water in each line....as it pushes out, that pressure will drop a bit, at which point, you can have DW shut the valve to that faucet.....and work her way around the RV until the last valve is blowing air.....use the pipes in the RV as your "tank", and just put the pressure to them.
Just be sure not to go to high on the pressure...I'd say 40-50 psi should be fine.
Good luck.
Good luck.
