Terryallan
Oct 03, 2013Explorer II
ScottnSherrie wrote:
If you can adjust pressure just turn it down low as it will go and make sure you always have one spigot open.
Forgot to mention that I also blow out the drains with a shop vac, hose on the exhaust. I also run some RV anti-freeze through the fresh water tank and pump.
If you blow all the liquid out of the traps. Wouldn't that allow the smell from the tank to come inside the RV????
