retiredtravelerExplorerOct 03, 2013Winterizing by blowing out linesHi All, Although we are going south in late November I would like to blow out the water lines. The only compressor I have is a small 120 unit designed to blow up tires etc. In other words high pressu...Show More
enblethenNomadOct 03, 2013Use the low pressure drain points and drain water heater. Then it will not take that much air to finish blowing them out.
Related ContentBlowing LinesHow to blow out lines to winterizeBlow out water lines questionBlowing out water lines for winter storage.Blowing out lines
