TweeterExplorerNov 21, 2015Winterizing Winnebago BusAnyone know how many gallons of antifreeze it takes to winterized a Winnebago 42 ft QD? I have already put in 5 gallons and it has not come thru the faucets yet. Thanks for help.
13 RepliesReplies sorted by NewestkiwiiamExplorerNov 28, 2015I have a similar unit - 3 Gallons max. I always run the back bathroom first, It takes just under 1 gallon to get that flowing antifreeze.IvylogExplorer IIINov 22, 2015If you do not winterize your Aquahot properly it could cost you thousands of dollars. Good luck.Agree it should not take 5 gallons to winterize your rig. Did you put the 5 gallons into your water tank?J-RoosterExplorerNov 21, 2015My Winnebago takes 2 gallonsJohno02ExplorerNov 21, 2015Remember that even a tankless system has water lines to and from, and some inside. Still needs to be drained, and or filled with antifreeze.donkeydewExplorerNov 21, 2015my 40 footer with aqua hot takes less than 2 gallons not including pea traps,washer or black tankmike_brezExplorerNov 21, 2015Are you dumping it in the fresh water tank or sucking it out of the bottle using your fresh water pump.TweeterExplorerNov 21, 2015This an aqua hot system (instant hot) tanklessJohno02ExplorerNov 21, 2015Without a water tank, 5 gallons seems to be a lot! Need to find out where it is all going.Johno02ExplorerNov 21, 2015No hot water?? If an instant heat, make sure it is either drained well, or has antifreeze it it also.gboppExplorerNov 21, 2015How are you putting the antifreeze in the water system?
Related ContentWinterizing tips and tricksShuttle bus conversionWinnebago qualityShuttle bus conversionSHUTLE BUS CONVERSION
