dougrainer
Apr 27, 2019Nomad
elargentino wrote:
I have a 2004 Fleetwood Bounder which I have always winterized with anti-freeze in the lines. Last fall I was talked into having it done with compressed air and yesterday, when I hooked up the water to flush the lines, I sprung a leak which came out of the bottom of the refrigerator (Dometic 3door, w/icemaker). I am no Columbo, but it seems to me that the icemaker is the most likely culprit. So is there a valve to shut off water to the icemaker? If the break (probable) is in the line after the shut-off valve, we could get along without an icemaker. If before the valve, obviously we'll have to fix the leak or we can't hook up to water. Anyone out there have a similar experience and how did you resolve it/ Is this a major problem (like having to remove the refrig?) or a relatively easy fix. HELP!
Obviously this is the last time I am using air to clear the lines!
The Dometic Icemaker solenoid is very visible when you remove the outside access door. Odds are that solenoid broke. You can remove the 1/4 inch line and cap it off. Doug
38,780 PostsLatest Activity: Aug 05, 2026
