et2
Apr 28, 2019Explorer
If you have a ice maker there is a "T" valve going to it ( most likely) the line will be a small 1/4" or so line ( probably yellow). Follow it until you see where it connect to the bigger main water line ( probably blue). Shut it off. I always disconnect mine when new and never worry about the fridge ice maker leaking. On this rig it's underneth inside the front bay.
But do make such when winterizing you winterize that valve too, no matter what. I just get a cup and let the air blow the water in it and red pop when added.
38,780 PostsLatest Activity: Aug 05, 2026
