larry_cad
Apr 28, 2019Explorer II
Lantley wrote:larry cad wrote:JaxDad wrote:
It might just be easier to learn how to do it properly.
For several years I used the pink stuff, and several years ago, I decided to do the air winterize procedure. Come spring, I put water in the coach and guess what, I had a leak. Now, here is the interesting part, the leak was behind my shower, in the water control spigot. Even more interesting is the mode of failure. The water control valve has a threaded hole in the bottom, and there was a nylon 1/2" pipe plug in it. In the top side of the pipe plug, was a depression molded in during manufacturing. If you look at a nylon pipe plug, you will see it. Since the depression was facing up, it remained filled with a tiny bit of water during the winterizing. During the winter, it froze and cracked. When I put water into the system, it ran out the crack.
So, as suggested above, I learned how to do it properly. Properly would be to remove the wall around my shower every winter, remove the plug, empty out the tiny bit of water remaining after I use compressed air, replace the plug, and my RV is winterized.
Or, I can just use the gallon of pink stuff I always had used in the past. Even though I now know how to do it "properly"!!
:S
This^^^ Is why you use the pink stuff. It is simply more foolproof.
Air is doable, but as mentioned there are more variables to deal with that simply are a non factor with anti freeze.
:B
38,782 PostsLatest Activity: Sep 20, 2026
