Lantley
Apr 29, 2019Nomad
JaxDad wrote:Lantley wrote:
THere is no Venturi effect or any other effect with anti freeze. Just put it in.It's foolproof
You quite correct, as Mr. Bernoulli proved the drop in pressure that creates the Venturi effect requires, and is in relation to, an increase in velocity caused by restricting the flow.
Since the little 12 volt water pump has very little flow, and with a tap open VERY little pressure compared to a good supply of air being released into the system at ~50 psi there is almost no Venturi effect at all.
The result?
That water left in the dead end of the T shaped pipe has very little chance of being vacuumed out and replaced, or even mixed with, that pink stuff.
There’s an old saying about ‘fool-proof’ ......
Just when you think it’s fool-proof, along comes a better fool.......
It also has very little chance of freezing and causing a problem. Don't overthink it. Antifreeze is that simple and that cheap.
As I said air is doable but there is more to know and more to do to ensure there are no problems.
Anti freeze does not have all of those variables.
If one is knowledgeable enough anti freeze maybe their preferred method.
But if you want to keep it simple and avoid the gotchas antifreeze is easier and just as effective.
38,782 PostsLatest Activity: Sep 20, 2026
