navegator
Nov 08, 2018Explorer
Look at where the lowest outlet tube is and tilt the RV with either a jack or a ramp made of wood so that as much water will drain out, thats what I do lean the RV to the side and drain, not all the water will be drained since the outlet tube is a little higer than the bottom of the tank.
navegator
navegator
38,766 PostsLatest Activity: Jan 10, 2026
