I ended up taking it to a place called RV Medic here locally and they found the problem, but only after they contacted Fleetwood. It seems Fleetwood redesigned their wiper system and there is a fuse near the battery (not shown in the Ford manual with all the other fuses) that blows on a pretty regular basis. They replaced the fuse and everything works again. Hopefully, this may save someone else $95 to fix a fuse. The RV Medic tech suggested I get a circuit breaker to replace the fuse so that when it blows again, it is a simple button push or the breaker will reset on it's own after it cools down.
